先前备份的S7-400的程序 现在打开组态时出现以下对话 one or more objects of a type cannot be represented unable to load serer's7hprxysdll'for S7H-STEUVERTETER-CT objects
make sure that the require optional pakage are installed
编译时出现以下对话框 the system data could not be recreated becaus the configuration is inconsistend 下载到新的CPU 后 CPU STOP 灯常亮
好像是组态不一致 但是程序是从原来的cpu上载的 已运行几年了 我把 IF 964-DP interface module 从组态中删掉后 编译正常 下载后 CPU RUN 灯亮 正常 但是和原来比少了一个DP 系统啊
