lince
查看lince的 主题 / 回贴
楼主  发表于: 2008-07-25 08:25
运动控制CPU软件 MT-DEVELOPER / SW6RNC-GSVE安裝后出現沒有找到SSCPDR6.dll 不能啟動,我已經重裝系統了,還是不行。有沒有人知道系統不兼容處理。
daizhi
一师一地一时一法
发帖数量: 1456 个
工控威望: 1376 点
下载积分: 3901 分
在线时间: 2976(小时)
查看daizhi的 主题 / 回贴
1楼  发表于: 2008-07-25 09:28
1) SNETP is not installed. Even if communication with the CPU is not made actually, SNETP must be installed. Refer to section 3.1 "Installation" to install the SW6RN-SNETP (Ver. 00B or later. If communication is made only with the Q172/Q173CPU, install SW6RN-SNETP.
• A list of applications for communication with the CPU is displayed. The following applications cause the phenomenon described to the left. (Applications other than those listed below operate without SNETP.)
GSV[ ][ ]P : Monitor, communication, program editor, install, mechanical system editor, test, backup, servo data setting (for writing to servo amplifier)
SW6RN-DOSCP: Digital oscilloscope
2) SNETP has been installed but is incompatible with the package given on the left. (SW6RN-SNETP (Ver. 00B or later) has been installed.) Refer to "3.7 Updating Instructions and Procedures" and update one set of SW6RNC-GSVE.
3) The PATH specified as the long name has been described in AUTOEXEC.BAT.
*: Long name: Folder name of 9 or more characters
Describe the SNETP PATH before the PATH specified as the long name, and always add "%PATH%" before the part where the long name has been specified. It is not required if it has already been described.
(Example)
• Before change SET PATH="C:\ProgramFiles\ABC;" (*1) SET PATH=%PATH%;C:\PROGRA~1\Sw6Sne~1; (*2)
• After change SET PATH=%PATH%;"C:\PROGRA~1\Sw6Sne~1;"SET PATH=%PATH%;"C:\ProgramFiles\ABC;"
*: Always described the (wiggly line) part.
(*1): Long name PATH
(*2): SNETP PATH
lince
查看lince的 主题 / 回贴
2楼  发表于: 2008-07-25 15:29
謝謝!沒有太懂,安裝后SYSTEM SETTING -GSV22P -MT DEVELOPER 正常開啟,SERVO DATASETTING正常開啟 PROGRAM EDITOR  ,MONITOR,不能使用 出現不能啟動
lince
查看lince的 主题 / 回贴
3楼  发表于: 2008-07-25 15:57
請大家指教,問題在SW6Snetpe,通訊程式
daizhi
一师一地一时一法
发帖数量: 1456 个
工控威望: 1376 点
下载积分: 3901 分
在线时间: 2976(小时)
查看daizhi的 主题 / 回贴
4楼  发表于: 2008-07-25 16:18
SW6RN-SNETP 安装没有?
zyfzxh
精华主题: 12 篇
发帖数量: 6112 个
工控威望: 7522 点
下载积分: 110390 分
在线时间: 4866(小时)
查看zyfzxh的 主题 / 回贴
5楼  发表于: 2008-07-25 19:07
楼主是不是Sw6Servome\DigitalOsiloScope.exe无法运行?
如果是就请将附件中的文件解压后存放到Sw6Servome文件夹中
附件: Sw6Servome_DigitalOsiloScope.rar (50 K) 下载次数:377
精华主题: 5 篇
发帖数量: 8135 个
工控威望: 10506 点
下载积分: 21392 分
在线时间: 3172(小时)
查看guochunyi的 主题 / 回贴
6楼  发表于: 2008-07-31 09:30
学习了,谢谢,看看。
xxjgk
发帖数量: 262 个
工控威望: 364 点
下载积分: 404 分
在线时间: 101(小时)
查看xxjgk的 主题 / 回贴
7楼  发表于: 2008-08-17 12:36
学习了谢谢!!!!
shijie2ooo
发帖数量: 6 个
工控威望: 166 点
下载积分: 621 分
在线时间: 0(小时)
查看shijie2ooo的 主题 / 回贴
8楼  发表于: 2008-08-18 11:04
斑竹太好了...
cuong
发帖数量: 47 个
工控威望: 199 点
下载积分: 10492 分
在线时间: 44(小时)
查看cuong的 主题 / 回贴
9楼  发表于: 2008-08-18 12:32
学习了谢谢!!!!
ps900
发帖数量: 29 个
工控威望: 175 点
下载积分: 466 分
在线时间: 10(小时)
查看ps900的 主题 / 回贴
10楼  发表于: 2008-12-07 06:44
什么问题
philsky
查看philsky的 主题 / 回贴
11楼  发表于: 2008-12-09 17:38
学习了谢谢!!!!
