jsh987321
发帖数量: 336 个
工控威望: 553 点
下载积分: 413 分
在线时间: 411(小时)
查看jsh987321的 主题 / 回贴
楼主  发表于: 2009-09-17 09:24
我的操作系统用的是精简版是SP2
我想安装SIMATIC_SQL2005_WinCC,可是安装不了,提示如下
MSI (s) (88:1C) [20:02:35:125]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (88:1C) [20:02:35:187]: End dialog not enabled
MSI (s) (88:1C) [20:02:35:187]: Original package ==> C:\WINDOWS\Installer\1c6b84.msi
MSI (s) (88:1C) [20:02:35:187]: Package we're running from ==> C:\WINDOWS\Installer\1c6b84.msi
MSI (s) (88:1C) [20:02:35:218]: APPCOMPAT: looking for appcompat database entry with ProductCode '{53F5C3EE-05ED-4830-994B-50B2F0D50FCE}'.
MSI (s) (88:1C) [20:02:35:234]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (88:1C) [20:02:35:265]: MSCOREE not loaded loading copy from system32
MSI (s) (88:1C) [20:02:35:453]: Original patch ==> I:\20_SQL2005\QFE\sqlsupport.msp
MSI (s) (88:1C) [20:02:35:453]: Patch we're running from ==> C:\WINDOWS\Installer\7f693.msp
MSI (s) (88:1C) [20:02:35:453]: SOFTWARE RESTRICTION POLICY: Verifying patch --> 'I:\20_SQL2005\QFE\sqlsupport.msp' against software restriction policy
MSI (s) (88:1C) [20:02:35:453]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (s) (88:1C) [20:02:35:453]: SOFTWARE RESTRICTION POLICY: I:\20_SQL2005\QFE\sqlsupport.msp is not digitally signed
MSI (s) (88:1C) [20:02:35:453]: SOFTWARE RESTRICTION POLICY: I:\20_SQL2005\QFE\sqlsupport.msp is permitted to run at the 'unrestricted' authorization level.
MSI (s) (88:1C) [20:02:35:468]: SequencePatches starts. Product code: {53F5C3EE-05ED-4830-994B-50B2F0D50FCE}, Product version: 9.00.3042.00, Upgrade code: {3A91FA19-A197-467C-850F-0AFE90899371}, Product language 1033
MSI (s) (88:1C) [20:02:35:468]: PATCH SEQUENCER WARNING: I:\20_SQL2005\QFE\sqlsupport.msp patch will not be sequenced because it does not contain any transform that may apply to product!
MSI (s) (88:1C) [20:02:35:484]: SequencePatches returns success.
MSI (s) (88:1C) [20:02:35:484]: Final Patch Application Order:
MSI (s) (88:1C) [20:02:35:484]: Other Patches:
MSI (s) (88:1C) [20:02:35:484]: Unknown\Absent: {273A9AD1-FC90-4732-85D7-3060E6AB974B} - I:\20_SQL2005\QFE\sqlsupport.msp
MSI (s) (88:1C) [20:02:35:500]: 产品: Microsoft SQL Server Setup Support Files (English) - 无法安装更新 '{273A9AD1-FC90-4732-85D7-3060E6AB974B}'。错误码 1642。可以在日志文件 C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0002_75DBF06774EF4CD_Support.log 中找到其他信息。
MSI (s) (88:1C) [20:02:35:515]: Note: 1: 1708
MSI (s) (88:1C) [20:02:35:515]: Note: 1: 2729
MSI (s) (88:1C) [20:02:35:531]: Note: 1: 2729
MSI (s) (88:1C) [20:02:35:546]: Product: Microsoft SQL Server Setup Support Files (English) -- Installation failed.
MSI (s) (88:1C) [20:02:35:546]: Attempting to delete file C:\WINDOWS\Installer\7f693.msp
MSI (s) (88:1C) [20:02:35:546]: MainEngineThread is returning 1642
Windows 安装服务无法安装升级修补程序,因为被升级的程序可能会丢失或是升级修补程序可能更新此程序的一个不同版本。请确认要被升级的程序在您的计算机上且您的升级修补程序是正确的。
MSI (c) (94:E4) [20:02:35:546]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (94:E4) [20:02:35:656]: MainEngineThread is returning 1642
=== Verbose logging stopped: 2009-9-16  20:02:35 ===
jsh987321
发帖数量: 336 个
工控威望: 553 点
下载积分: 413 分
在线时间: 411(小时)
1楼  发表于: 2009-09-17 09:25
请问怎样解决
精华主题: 5 篇
发帖数量: 8271 个
工控威望: 10403 点
下载积分: 21155 分
在线时间: 3066(小时)
查看guochunyi的 主题 / 回贴
2楼  发表于: 2009-09-17 11:43
把系统弄成非精简的。不论是操作系统升级或者重新安装。
