wu1111bin
12345
发帖数量: 68 个
工控威望: 369 点
下载积分: 3853 分
在线时间: 46(小时)
查看wu1111bin的 主题 / 回贴
楼主  发表于: 34天前
2024.12.29 19:15:21 - Year.Month.Day - Log start
BUNDLE: SIMATIC TIA Portal V17 WinCC Prof Ed
SEBU Version: Professional:TIA.rgs.RTM_17000000:V17.00.00.00_43.02.00.01
OS: Microsoft Windows 10 专业版 Professional, 64-bit, build 19041
COMMANDLINE: C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant\408\SIA2.exe /starter /bundlepath=D:\02.主程序)TIA_PORTAL_STEP7_PROF_SAFETY_WINCC_PROF_V17\InstData
INSTALLDIR: C:\Program Files\Siemens\Automation
SETUPLANGUAGE: 2052
PRODUCTLANGUAGES: 1033;2052
CHANGES: (+)DotNet_Updater;(+)VC_2005_REDIST_X64;(+)VC_2008_REDIST_x64;(o)SQLNCLI;(+)SYMLINK;(+)SYMLINKADD;(+)OPCCORECOMP64;(+)NCMGPRS64;(+)NCMFWL64;(+)WinCC ACE;(+)WinCC Common Archiving;(+)OPC;(+)Runtime Interfaces;(+)HMIProvider;(+)SECON;(+)S7EDB;(+)TIA_Portal;(+)MU_Client;(+)HWCN-HWCOL;(+)SUPBASEH02;(+)SUPBASEH03;(+)SUPBASEH04;(+)SUPBASETO01;(+)SUPBASETO02;(+)SUPBASEWCF01;(+)TIAP_SIMATIC;(+)TIAP_SIMATIC32;(+)STEP7;(+)WinCC Runtime Advanced Simulator;(+)PTSymLib;(+)PTTouchInput;(+)HM_AllEditions;(+)HM_NoBasic;(+)STOBS;(+)UMC64;(+)UMTRAYICON;(+)STOP_ALMSERVICE;(+)AlmPanelPlugin64;(+)Prosave;(+)TIA_ES;(+)TIA_ES32;(+)WinCC_Tr_Mandatory;(+)SCADA-RT;(+)RT_Pro_Sim;(+)CoRtHmiRTmDriver64;(+)HMIRTMV11;(+)RT_Adv_Sim;(+)TIACOMPCHECK;(+)S7FPLUS;(+)TIA_Opns;(+)OptionVCI;(+)ETWEventCollector;(+)TelemetryConnector;(+)OPCUA_Client;(+)TIAADMIN;(+)AWB_SOFT;(+)AWB_ALM;(+)AWB_TIAUMAC;(+)MUSERVER
There are NO severe messages before the installation
19:15:21 | BEGIN. Execution started.
19:15:24 | OK                        RunningProcesses           ()                          Complete
19:15:24 | OK                        InventoryBefore            (A)                         Complete
19:15:24 | OK                        Citamis                    (Before)                    Complete
19:18:00 | OK                        SecurityControlFeature     (ReturnFeatures)            Complete
19:18:00 | OK                        StartApplBefore            (TIAP17::[INSTALLDIR]BIN\SIEMENS.AUTOMATION.OBJECTFRAME.FILESTORAGE.SERVER.EXE)Complete
19:18:00 | OK                        StartApplBefore            (TIAADMIN::[INSTALLDIR]SERVER\NODE.EXE)Complete
19:18:00 | OK                        StartApplBefore            (TIAP17::[INSTALLDIR]X64\BIN\SIEMENS.AUTOMATION.OBJECTFRAME.FILESTORAGE.SERVER.EXE)Complete
19:18:00 | OK                        ClassicCompPrepare         ()                          Complete
19:18:00 | OK                        ProductRegistration        (Before)                    Complete
19:18:00 | OK                        ClassicCompAfterUninstall  ()                          Complete
19:18:00 | OK                        SetupUnit                  (DotNet_Updater)            Complete  Foreign   AddLocal
19:18:03 | OK                        SetupUnit                  (VC_2005_REDIST_X64)        Complete  Foreign   AddLocal
19:18:05 |ERROR    AdsWorkerForeignExe::GetInstallResult():  - 1638: assuming unknown error, because return value is not in OK-list which is only defined. Please check the corresponding log file for more detailed information
19:18:05 | FAIL!                     SetupUnit                  (VC_2008_REDIST_x64)        Failed    Foreign   AddLocal
19:18:05 | FAIL!                     Checkpoint                 (RE)                        Complete
19:18:05 |ERROR    ExecutionEngine::StartNextStepAsync():  - Execution has been cancelled. Probably because of some process(es) running on the machine
19:18:05 | SKIP!                     SetupUnit                  (SQLNCLI)                   Skip      Foreign   Reinstall
19:18:05 | SKIP!                     Checkpoint                 (E)                         Skip
19:18:05 | SKIP!                     SetupUnit                  (SYMLINK)                   Skip      Foreign   AddLocal
19:18:05 | SKIP!                     SetupUnit                  (SYMLINKADD)                Skip      Foreign   AddLocal
19:18:05 | SKIP!                     SetupUnit                  (OPCCORECOMP64)             Skip      Foreign   AddLocal
19:18:05 | SKIP!                     SetupUnit                  (NCMGPRS64)                 Skip      ClassicComponentAddLocal
19:18:05 | SKIP!                     SetupUnit                  (NCMFWL64)                  Skip      ClassicComponentAddLocal
19:18:05 | SKIP!                     SecurityControl            (WinCC ACE)                 Skip
19:18:05 | SKIP!                     SetupUnit                  (WinCC ACE)                 Skip      ClassicComponentAddLocal
海浪轮回
发帖数量: 42 个
工控威望: 175 点
下载积分: 5422 分
在线时间: 83(小时)
查看海浪轮回的 主题 / 回贴
1楼  发表于: 32天前
博途好像卸不干净,见好多人都是重装系统
