softtest
发帖数量: 20 个
工控威望: 94 点
下载积分: 474 分
在线时间: 4(小时)
查看softtest的 主题 / 回贴
楼主  发表于: 2018-04-18 11:04
近日在学习昆仑通态资料,写了一个反编译工具 ,但发现一遍反编译的话,while 指令还原不了。哪位有什么好建议没?
'自定义子函数:DoStrCrc16。
'函数原型为: FUNCTION DoStrCrc16(strProtocol AS STRING) AS INTEGER
'这部分注释请勿修改,请在下面编辑内容:
'———————————————————————        DoStrCrc16(strProtocol as string) as integer
dim iLen as integer        |dim Ta as integer
dim iSum as byte        |dim Tb as byte
dim pData(1) as byte        |dim Va(1) as byte
dim ulSeed as integer        |dim Tc as integer
dim i    as integer        |dim Td as integer
dim sel  as integer        |dim Te as integer
dim wCRC16a(16) as integer        |dim Vb(16) as integer
dim wCRC16b(16) as integer        |dim Vc(16) as integer
wCRC16a[1]=0        |   Vb[1]= 0
wCRC16a[2]=49345        |   Vb[2]= 49345
wCRC16a[3]=49537        |   Vb[3]= 49537
wCRC16a[4]=320        |   Vb[4]= 320
wCRC16a[5]=49921        |   Vb[5]= 49921
wCRC16a[6]=960        |   Vb[6]= 960
wCRC16a[7]=640        |   Vb[7]= 640
wCRC16a[8]=49729        |   Vb[8]= 49729
wCRC16a[9]=50689        |   Vb[9]= 50689
wCRC16a[10]=1728        |   Vb[10]= 1728
wCRC16a[11]=1920        |   Vb[11]= 1920
wCRC16a[12]=51009        |   Vb[12]= 51009
wCRC16a[13]=1280        |   Vb[13]= 1280
wCRC16a[14]=50625        |   Vb[14]= 50625
wCRC16a[15]=50305        |   Vb[15]= 50305
wCRC16a[16]=1088        |   Vb[16]= 1088
wCRC16b[1]=0        |   Vc[1]= 0
wCRC16b[2]=52225        |   Vc[2]= 52225
wCRC16b[3]=55297        |   Vc[3]= 55297
wCRC16b[4]=5120        |   Vc[4]= 5120
wCRC16b[5]=61441        |   Vc[5]= 61441
wCRC16b[6]=15360        |   Vc[6]= 15360
wCRC16b[7]=10240        |   Vc[7]= 10240
wCRC16b[8]=58369        |   Vc[8]= 58369
wCRC16b[9]=40961        |   Vc[9]= 40961
wCRC16b[10]=27648        |   Vc[10]= 27648
wCRC16b[11]=30720        |   Vc[11]= 30720
wCRC16b[12]=46081        |   Vc[12]= 46081
wCRC16b[13]=20480        |   Vc[13]= 20480
wCRC16b[14]=39937        |   Vc[14]= 39937
wCRC16b[15]=34817        |   Vc[15]= 34817
wCRC16b[16]=17920        |   Vc[16]= 17920
  iSum = 0        |   Tb= 0
  ulSeed=0        |   Tc= 0
  i=1        |   Td= 1
  iLen=!len(strProtocol)        |   Ta= !len( strProtocol)
  if iLen>0 then        |   IF   Ta > 0 THEN
     iLen=!arrayResize(pData,iLen)        |      Ta= !ArrayResize( Va , Ta)
     if !Str2ByteArr(strProtocol,pData)<>0 then        |      IF   !Str2ByteArr( strProtocol , Va) <> 0 THEN
      iSum=-1        |         Tb= -1
      exit        |         EXIT
   endif        |      ENDIF
   while iLen        |      IF   Ta THEN
     iSum=!BitXor(pData,uLseed)        |         Tb= !BitXor( Va[Td] , Tc)
     ulSeed=!BitXor(!BitXor(!BitRShift(ulSeed,8),wCRC16a[!BitAnd(iSum,&H0F)+1]),wCRC16b[!BitRShift(iSum,4)+1]) |         Tc= !BitXor( !BitXor( !BitRShift( Tc , 8) , Vb[!BitAnd( Tb , 15) + 1]) , Vc[!BitRShift( Tb , 4) + 1])
     iLen=iLen-1        |         Ta= Ta - 1
     i=i+1        |         Td= Td + 1
   endwhile        |      EndWhile      ENDIF
  endif        |   ENDIF
  DoStrCrc16=!BitAnd(ulSeed,&Hffff)        |   DoStrCrc16= !BitAnd( Tc , 65535)
        |   EXIT
左边为设备原代码,后面为反编译还原后的。
softtest
发帖数量: 20 个
工控威望: 94 点
下载积分: 474 分
在线时间: 4(小时)
查看softtest的 主题 / 回贴
1楼  发表于: 2018-04-18 11:21
CollectData设备采集函数() as Void
dim Ta as integer
dim Tb as integer
dim Tc as string
dim Td as string
dim Te as string
dim Tf as string
dim Va(0) as byte
dim Vb(0) as byte
dim Vc(0) as byte
dim Tg as integer
dim Th as integer
dim Ti as single
dim Tj as integer
   Ta= 0
   Tb= 0
   !ArrayResize( Va , 12)
   Va[1]= 0
   Va[2]= 1
   Va[3]= 2
   Va[4]= 3
   Va[5]= 4
   Va[6]= 5
   Va[7]= 6
   Va[8]= 7
   Va[9]= 8
   Va[10]= 9
   Va[11]= 0
   Va[12]= 0
   !SvrGetIntFromByteArr( Va , 2 , Ta , 1)
   !ArrayResize( Va , 8)
   Va[1]= 设备属性00
   Va[2]= 3
   Va[3]= 0
   Va[4]= 0
   Va[5]= 0
   Va[6]= 8
   Tg= !SvrByteArrayModbusCRC( Va , 1 , 6)
   Va[7]= !BitAnd( Tg , 255)
   Th= !BitAnd( Tg , 65280)
   Va[8]= !BitRShift( Th , 8)
   !ArrayResize( Vb , 21)
   Tg= !DevWriteAndReadByteArr( Va , 8 , Vb , 21 , 设备属性01)
   IF   Tg <> 21 THEN
      !SetSingleChannelValueByName( "通讯状态" , 2)
      EXIT
   ENDIF
   Ta= 0
   !ArrayResize( Vc , 2)
   IF   Ta < 8 THEN
      Vc[1]= Vb[Ta * 2 + 5]
      Vc[2]= Vb[Ta * 2 + 4]
      Tg= !SvrGetShortFromByteArr( Vc , 1 , Tj , 0)
      Ti= Tj
      !SetSingleChannelValueByNum( Ta + Tb + 2 , Ti)
      Ta= Ta + 1
   EndWhile   ENDIF
   Tb= Tb + Ta
   !SetSingleChannelValueByName( "通讯状态" , 0)
   EXIT
