小宇宙0312
发帖数量: 17 个
工控威望: 122 点
下载积分: 1321 分
在线时间: 61(小时)
查看小宇宙0312的 主题 / 回贴
楼主  发表于: 2016-08-22 14:19
1       [00000000]  IRP_MJ_CREATE                   Port Opened - WPLSoft.exe
2       [00000000]  IOCTL_SERIAL_SET_BAUD_RATE      Baud Rate: 9600
3       [00000000]  IOCTL_SERIAL_SET_LINE_CONTROL   StopBits: 1, Parity: Even, DataBits: 7
4       [00000000]  IOCTL_SERIAL_SET_BAUD_RATE      Baud Rate: 9600
5       [00000000]  IOCTL_SERIAL_SET_LINE_CONTROL   StopBits: 1, Parity: Even, DataBits: 7
6       [00000000]  IOCTL_SERIAL_SET_BAUD_RATE      Baud Rate: 9600
7       [00000000]  IOCTL_SERIAL_SET_LINE_CONTROL   StopBits: 1, Parity: Even, DataBits: 7
8       [00000001]  IOCTL_SERIAL_SET_BAUD_RATE      Baud Rate: 9600
9       [00000001]  IOCTL_SERIAL_SET_LINE_CONTROL   StopBits: 1, Parity: Even, DataBits: 7
10      [00000001]  IRP_MJ_WRITE                    Length: 0004, Data: 41 54 5A 0D
11      [00000131]  IRP_MJ_WRITE                    Length: 0009, Data: 3A 30 31 31 31 45 45 0D 0A
12      [00000132]  IRP_MJ_READ                     Length: 0012, Data: 3A 30 31 31 31 31 32 30 31 46 46 38
13      [00000134]  IRP_MJ_READ                     Length: 0020, Data: 38 33 34 32 30 30 38 30 30 30 45 46 46 30 30 46 46 30 30 46
14      [00000135]  IRP_MJ_READ                     Length: 0015, Data: 46 46 46 46 46 46 46 46 46 46 46 46 32 0D 0A
15      [00000136]  IRP_MJ_WRITE                    Length: 0017, Data: 3A 30 31 30 31 30 43 32 44 30 30 30 31 43 34 0D 0A
16      [00000138]  IRP_MJ_READ                     Length: 0013, Data: 3A 30 31 30 31 30 31 32 43 44 31 0D 0A
17      [00000139]  IRP_MJ_WRITE                    Length: 0017, Data: 3A 30 31 36 37 30 30 31 30 30 30 30 35 38 33 0D 0A
18      [00000141]  IRP_MJ_READ                     Length: 0018, Data: 3A 30 31 36 37 30 41 30 30 30 33 34 30 30 30 30 30 30
19      [00000142]  IRP_MJ_READ                     Length: 0013, Data: 31 30 30 30 45 30 30 30 30 33 43 0D 0A
20      [00000143]  IRP_MJ_WRITE                    Length: 0017, Data: 3A 30 31 36 34 30 31 32 41 30 31 30 30 36 46 0D 0A
21      [00000145]  IRP_MJ_READ                     Length: 0017, Data: 3A 30 31 36 34 30 31 32 41 30 31 46 46 37 30 0D 0A
