iproffice
发帖数量: 15 个
工控威望: 110 点
下载积分: 638 分
在线时间: 5(小时)
查看iproffice的 主题 / 回贴
楼主  发表于: 2016-05-03 07:18
http://www.fa.omron.co.jp/product/tool/454/sysmac-studio/e1_doc.html
Support of New Type
Supported the following CPU Units.
NJ701 CPU Units Ver. 1.11
NJ501 CPU Units Ver. 1.11
NJ301 CPU Units Ver. 1.11
NJ101 CPU Units Ver. 1.11
Supported the following Units.
Modular Temperature Controller: EJ1N-HFUC-ECT
ZW-7000-series Confocal Fiber Displacement Sensor: ZW-7000[]
FH-series Vision Sensor: FH-1[][][], FH-3[][][] Ver. 5.60
Supported the FH Series Ver. 5.60.
 Supported the FH-SM05R/FH-SC05R 5M Cameras.
Supported the Adept Robot Controllers as a configurable device in the EtherNet/IP Connection Settings.
New functions
Provided a function to specify where the right bus bar should be displayed in the Ladder Editor.
Supported auto startup of Japanese IME when editing variable comments in the variable tables and Ladder Editor.
Provided a function to directly specify variables in the Cross Reference tab page.
Provided a function to automatically close the tab page that has not become active for the longest time when the maximum number of tab pages is exceeded by opening a new tab page.
<Related to Displacement Sensors>
Provided a function to edit the configuration of ZW-7000 Series.
<Related to Safety>
Supported the simple automatic test function with the offline simulator.
Added the following functions in the Safety Slave Unit Parameter Settings view.
- Easy switching between the setting views of each Unit.
- Settings of the ESTOP pushbutton and Safety Light Curtain and other devices.
- Display of contacts/wirings of devices
- Copy & paste of devices
Supported the jump function to the next/previous variable from the context menu displayed in the FBD Editor.
Provided a function to add user-defined FB and data type conversion instructions from the Toolbox in the FBD Editor.
Added an option to print the safety signature code in the Print Setup view.
Improved functions
Improved so that variable comments can be edited in the Ladder Program during online editing.
Improved so that the section name is displayed in the title of ladder diagrams in the detailed comparison view of online comparison.
Shortened the startup time of the Measurement Sensor Edition.
Solved the problem that the contents of the displayed variable comments were not unified.
Solved the problem that the cursor returned to the previous edit position if the view was scrolled and another location was selected while editing a variable in the Ladder Editor.
Solved the problem that the list of cross reference became incorrect after replacing a variable in a ladder diagram.
Improved so that the display height of the detailed information can be changed in the Troubleshooting Dialog Box.
Improved so that the number of samples can be changed in the data trace operations.
Solved the problem that the data might not be printed properly if the rungs were wrapped.
Improved the EtherCAT Diagnosis/Statistics Information tab page so that EtherCAT configuration diagram and error frame information can be displayed in a single tab page.
Improved so that the present values of retainable member and element variables can be retained when a retained structure/union variable member or a retained array element member is added, deleted, or changed and then transferred to the Controller. (CPU Unit with unit Ver. 1.11 or later)
Improved so that other groups are not collapsed when a group is expanded.
Added the Expand All and Collapse All commands to the context menu of Toolbox so that all groups can be expanded/collapsed at the same time.
<Related to Displacement Sensor>
Separated the sensing monitor view from each edit view.
Improved the main view, sensing monitor view, bank data edit view, system data edit view, and print view so that they can be opened at the same time.
Improved the visibility of edit views by changing the parameter area to a list form.
Improved the axis scale so that it is static in the trend monitor.
Added a function to output setting parameters to a CSV file.
<Related to Safety>
Solved the problem that starting up the offline simulator might fail.
Solved the problem that programs might not match when opening a project after safety validation.
Solved the problem that a build error might occur when importing an old configuration file of a Safety Control Unit.
Solved the problem that variable tables could be edited and projects could be imported/exported while online.
<Related to HMI>
Solved the problem that a build error might occur in the projects created with Sysmac Studio Ver. 1.13 or lower.
Solved the problem that the software temporarily froze when operating an object.
Solved the problem that a build error occurred after executing a replacement operation even if the view looks no problem.
[Runtime] Solved the problem that external variable values did not match the values in the Controller in high-load projects.
[Runtime] Solved the problem that NA's performance might be lowered during online editing of the Controller.
[Runtime] Solved the problem that the view might not be refreshed when a structure was assigned to a data input object on the tab control.
[Runtime] Solved the problem that text of a toggle button was not displayed correctly the first time the tab control was displayed.
dj1178
发帖数量: 1800 个
工控威望: 2114 点
下载积分: 51132 分
在线时间: 1219(小时)
查看dj1178的 主题 / 回贴
1楼  发表于: 2016-05-04 08:06
又没有软件下载
guolibin
auto_glb@qq.com
发帖数量: 642 个
工控威望: 1036 点
下载积分: 5372 分
在线时间: 295(小时)
查看guolibin的 主题 / 回贴
2楼  发表于: 2016-05-05 15:17
链接: http://pan.baidu.com/s/1qXHPGZy 密码: szgm
V1.15
  • 下载积分:+5(lishunlong86) 真诚感谢!
    dj1178
    发帖数量: 1800 个
    工控威望: 2114 点
    下载积分: 51132 分
    在线时间: 1219(小时)
    查看dj1178的 主题 / 回贴
    3楼  发表于: 2016-05-05 16:01
    引用第2楼guolibin于2016-05-05 15:17发表的  :
    V1.15
    果版主牛
    roy_poon
    发帖数量: 114 个
    工控威望: 237 点
    下载积分: 64393 分
    在线时间: 604(小时)
    查看roy_poon的 主题 / 回贴
    4楼  发表于: 2016-05-06 02:00
    谢谢分享。
    chris_007
    发帖数量: 86 个
    工控威望: 198 点
    下载积分: 653 分
    在线时间: 69(小时)
    查看chris_007的 主题 / 回贴
    5楼  发表于: 2016-05-10 17:06
    谢谢分享
    舜天水怪
    非标小学徒
    发帖数量: 91 个
    工控威望: 188 点
    下载积分: 737 分
    在线时间: 112(小时)
    查看舜天水怪的 主题 / 回贴
    6楼  发表于: 2016-05-16 23:03
    这个序列号 除了问供应商要 还有其他的途径没
    彭万生
    发帖数量: 1890 个
    工控威望: 2102 点
    下载积分: 131756 分
    在线时间: 1278(小时)
    查看彭万生的 主题 / 回贴
    7楼  发表于: 2016-09-22 09:31
    x谢谢分享
    仙居人家
    我来了。
    精华主题: 2 篇
    发帖数量: 740 个
    工控威望: 5423 点
    下载积分: 26505 分
    在线时间: 1384(小时)
    查看仙居人家的 主题 / 回贴
    8楼  发表于: 2016-09-22 11:12
    最新的吗?
    永无止境 !@#$%^&*
    天下风云出我辈,一入江湖岁月催。
    皇图霸业谈笑中,不胜人间一场醉。
    提剑跨骑挥鬼雨,白骨如山鸟惊飞。
    尘事如潮人如水,只叹江湖几人回。
    peoplehehe
    发帖数量: 3 个
    工控威望: 95 点
    下载积分: 553 分
    在线时间: 17(小时)
    查看peoplehehe的 主题 / 回贴
    9楼  发表于: 2016-09-24 11:44
    都下载不了啦
    liue
    发帖数量: 91 个
    工控威望: 231 点
    下载积分: 32302 分
    在线时间: 182(小时)
    查看liue的 主题 / 回贴
    10楼  发表于: 2016-10-18 21:12
    谢谢分享
