电力专业英语
carrie85
lj0185
(1) 元件设备
三绕组变压器:three-column transformer ThrClnTrans
双绕组变压器:double-column transformer DblClmnTrans
电容器:Capacitor
并联电容器:shunt capacitor
电抗器:Reactor
母线:Busbar
输电线:TransmissionLine
发电厂:power plant
断路器:Breaker
刀闸(隔离开关):Isolator
分接头:tap
电动机:motor
(2) 状态参数
有功:active power
无功:reactive power
电流:current
容量:capacity
电压:voltage
档位:tap position
有功损耗:reactive loss
无功损耗:active loss
功率因数:power-factor
功率:power
功角:power-angle
电压等级:voltage grade
空载损耗:no-load loss
铁损:iron loss
铜损:copper loss
空载电流:no-load current
阻抗:impedance
正序阻抗:positive sequence impedance
负序阻抗:negative sequence impedance
零序阻抗:zero sequence impedance
电阻:resistor
电抗:reactance
电导:conductance
电纳:susceptance
无功负载:reactive load 或者QLoad
有功负载: active load PLoad
遥测:YC(telemetering)
具体内容见附件:
