测试成块的数据读取
#Region "测试成块的数据读取"
Private Sub btn_ReadDeviceBlock2_Click(sender As Object, e As EventArgs) Handles btn_ReadDeviceBlock2.Click
Dim iReturnCode As Integer 'Return code
Dim szDeviceName As String = "" 'List data for 'DeviceName'
Dim iNumberOfDeviceName As Integer = 0 'Data for 'DeviceSize'
Dim sharrDeviceValue() As Short 'Data for 'DeviceValue'
Dim szarrData() As String 'Array for 'Data'
Dim iNumber As Integer 'Loop counter
'Displayed output data is cleared.
ClearDisplay()
'Get the list of 'DeviceName'.
' Join each line(StringType array) of 'DeviceName' by the separator '\n',
' and create a joined string data.
szDeviceName = String.Join(vbLf, txt_DeviceNameBlock.Lines)
'Check the 'DeviceSize'.(If succeeded, the value is gotten.)
If GetIntValue(txt_DeviceSizeBlock, iNumberOfDeviceName) = False Then
'If failed, this process is end.
Exit Sub
End If
'Assign the array for 'DeviceValue'.
ReDim sharrDeviceValue(iNumberOfDeviceName - 1)
Try
iReturnCode = AxActUtlType1.ReadDeviceBlock2(szDeviceName, iNumberOfDeviceName, sharrDeviceValue(0))
Catch exException As Exception
MessageBox.Show(exException.Message, Name, MessageBoxButtons.OK, MessageBoxIcon.Error)
Exit Sub
End Try
txt_ReturnCode.Text = String.Format("0x{0:x8} [HEX]", iReturnCode)
If iReturnCode = 0 Then
'Assign array for the read data.
ReDim szarrData(iNumberOfDeviceName - 1)
'Copy the read data to the 'lpszarrData'.
For iNumber = 0 To iNumberOfDeviceName - 1
szarrData(iNumber) = sharrDeviceValue(iNumber).ToString()
Next iNumber
'Set the read data to the 'Data', and display it.
txt_Data.Lines = szarrData
End If
End Sub
#End Region
![](http://www.ymmfa.com/attachment/Mon_1807/52_195840_c3ae29e32edcc59.jpg)
