手册
画出步进阶梯图 并且解说动作`~~这是(水冷式箱型冷气控制)
vn504507a
查看vn504507a的
发表于: 2007-11-11 15:07
急用~~急用~~急用~~
e-mail ~~ (
49322071@webmail.stut.edu.tw
*****************************程式指令***************************
0 LD M8002
1 ZRST S0 S999
6 SET S4
8 LD Y023
9 ANI X016
10 LD Y022
11 ANI X015
12 ORB
13 LD Y021
14 ANI X014
15 ORB
16 ZRST S4 S599
21 SET S0
23 LDI X006
24 ZRST S4 S599
29 LDP X006
31 SET S4
33 LD Y021
34 ANI X011
35 LD Y022
36 ANI X012
37 ORB
38 LD Y023
39 ANI X013
40 ORB
41 LDI Y021
42 AND X011
43 ORB
44 LDI Y022
45 AND X012
46 ORB
47 LDI Y023
48 AND X013
49 ORB
50 ANS TO K5 S900
57 LD S900
58 ZRST S0 S899
63 ZRST Y020 Y037
68 STL S4
69 LD X016
70 AND X003
71 SET S41
73 LD X016
74 AND X002
75 SET S54
77 STL S41
78 OUT Y023
79 OUT Y033
80 LD X015
81 AND X004
82 SET S42
84 SLT S51
85 OUT T3 K50
88 OUT Y023
89 LD M8013
90 OUT Y033
91 LD T3
92 SET S52
94 STL S42
95 OUT Y023
96 OUT Y022
97 OUT Y033
98 OUT Y032
99 LD X014
100 AND X005
101 SET S43
103 STL S52
104 OUT T4 K100
107 OUT Y023
108 OUT Y022
109 OUT Y023
110 LD M8013
111 OUT Y032
112 LD T4
113 OUT S43
115 STL S43
116 OUT Y023
117 OUT Y022
118 OUT Y021
119 OUT Y033
120 OUT Y032
121 OUT Y031
122 LD X001
123 SET S44
125 STL S44
126 OUT T1 K50
129 OUT Y023
130 OUT Y023
131 OUT Y033
132 LD M8013
133 OUT Y032
134 LD T1
135 SET S45
137 STL S45
138 OUT T2 K100
141 OUT Y023
142 LD M8013
143 OUT Y033
144 LD T2
145 OUT S4
147 STL S0
148 LD X000
149 AND M8013
150 OUT Y020
151 LD X000
152 AND M8013
153 OR X10
154 OUT Y034
155 LD X014
156 AND X015
157 AND X016
158 RST S0
160 STL S0
161 LD X000
162 AND M8013
163 OUT Y000
164 LD X000
165 ANI M8013
166 OR X010
167 OUT Y014
168 LD X014
169 AND X015
170 AND X016
171 SET S4
173 RET
174 END
wanghuhong
2 篇
1544 个
10484 点
9755 分
在线时间: 897(小时)
查看wanghuhong的
发表于: 2007-11-11 15:38
wangfang110
查看wangfang110的
发表于: 2007-11-12 21:14
小朋友,把指令输入GP里不就行了吗!!!!!!! GP 有几种编程方式,你用语句表写用LAD读!!!!!!!!!!
a7935508
42 个
179 点
682 分
在线时间: 4(小时)
查看a7935508的
发表于: 2007-11-13 12:29
