gongkkk
发帖数量: 93 个
工控威望: 236 点
下载积分: 1380 分
在线时间: 22(小时)
查看gongkkk的 主题 / 回贴
楼主  发表于: 2017-12-04 11:35
系统win7 64 旗舰,原装系统。试了几次了,还是不行,消息队列已装。
错误代码:
2017.12.04 09:55:44 - Year.Month.Day - Log start
BUNDLE: SIMATIC WinCC Professional V14.0 SP1
SEBU Version: Professional:TIA.rgs.RTM_14000100:V14.00.01.00_12.01.00.01
OS: Microsoft Windows 7 专业版  Professional, Service Pack 1, 64-bit, build 7601
COMMANDLINE: C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant\401\SIA2.exe /starter /bundlepath=\\VMWARE-HOST\SHARED FOLDERS\SHARE\WINCC PROF V14SP1\InstData
INSTALLDIR: C:\Program Files\Siemens\Automation\
SETUPLANGUAGE: 2052
PRODUCTLANGUAGES: 1033;2052
There are NO severe messages before the installation
10:45:49 |ERROR    AdsWorkerClassicComponent::OnWorkerCompleted():  - ClassicComponent setup result: Unexpected exception
10:45:49 | FAIL!                     SetupUnit (S7DOS64), Failed -  - ClassicComponent, AddLocal
10:50:12 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:50:12 | FAIL!                     SetupUnit (TIAP_SIMATIC), Failed -  - PlusOptional, AddLocal
10:51:10 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:51:10 | FAIL!                     SetupUnit (STEP7), Failed -  - PlusOptional, AddLocal
10:52:14 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:52:14 | FAIL!                     SetupUnit (HM_AllEditions), Failed -  - PlusOptional, AddLocal
10:52:40 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:52:40 | FAIL!                     SetupUnit (HM_NoBasic), Failed -  - PlusOptional, AddLocal
10:52:58 |ERROR    AdsWorkerClassicProduct::OnWorkerCompleted():  - ClassicProduct setup result: :
10:52:58 | FAIL!                     SetupUnit (Prosave), Failed -  - ClassicProduct, AddLocal
10:54:18 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:54:18 | FAIL!                     SetupUnit (TIA_ES), Failed -  - PlusOptional, AddLocal
10:54:21 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:54:21 | FAIL!                     SetupUnit (TIA_ES32), Failed -  - PlusOptional, AddLocal
11:00:51 |ERROR    AdsWorkerForeignExe::GetInstallResult():  - -1: assuming unknown error, because return value <> 0 and either OK- nor ERROR-values are defined. Please check the corresponding log file for more detailed information
11:00:51 | FAIL!                     StartApplAfter (TIAP14::[INSTALLDIR]BIN\SIEMENS.AUTOMATION.GENERATOR.FRAMEWORK.EXE), Failed
11:01:08 | OK                        StartApplAfter (TIAP14::C:\WINDOWS\SYSWOW64\S7EPATSX.EXE), Complete
11:01:55 | OK                        StartApplAfter (TIAP14::C:\WINDOWS\SYSWOW64\S7EPAESX.EXE), Complete
11:01:55 |ERROR    AdsWorkerForeignExe::GetInstallResult():  - -1: assuming unknown error, because return value <> 0 and either OK- nor ERROR-values are defined. Please check the corresponding log file for more detailed information
11:01:55 | FAIL!                     StartApplAfter (TIAP14::[INSTALLDIR]BIN\SIEMENS.SIMATIC.HWCN.INTERPRETER.IG.GSD.GENERATOR.EXE), Failed
11:02:29 | END. Execution completed.
Intermediate ExitCode after execution queue: 1603
Errors: 10
Warnings: 0
如图所示:
蒲城风信子
微信QQ1733946494
发帖数量: 555 个
工控威望: 777 点
下载积分: 1306 分
在线时间: 287(小时)
查看蒲城风信子的 主题 / 回贴
1楼  发表于: 2017-12-05 07:15
我也是安装报错
千桦飞翎
发帖数量: 136 个
工控威望: 922 点
下载积分: 1111 分
在线时间: 17(小时)
查看千桦飞翎的 主题 / 回贴
2楼  发表于: 2017-12-05 09:21
就是古来看下的
